Does anyone know where I can get blank aluminium Cortina hubs from ?
I want to run wheels with a different PCD and ideally not have an extra set of holes.
James
edit : and while were on it, can I get blank rear hubs aswell ???
[Edited on 20/2/08 by Jeffers_S13]
look here
one of the companies does 5 hole hubs so I guess if you speak to them, they should be able to drill to your PCD, or supply undrilled.
Originally posted by Jeffers_S13
edit : and while were on it, can I get black rear hubs aswell ???
If you mean black anodised rear hubs, you won't find any in anything but steel. The splines would just strip if they were alloy ...... so I guess the Smoothrite is the best option.
Haha ! sorry, no I mean 'blank', not necessarily alloy, I want a different PCD on the back aswell.
I am most likely going to accomodate the different PCD with an adapter/spacer, but a new hub would be the nicest solution.
