Here are my "locost" floor mounted pedals (hydraulic clutch and brake).
Not very pretty but I thought I'd have a go.
Actually it wasn't very locost as I bought new master cylinders, and the dual-circuit brake one wasn't cheap!!
I'll keep the Sierra accelerator pedal as standard (not floor mounted).
how thick is the floor ?
wait till you can hold some pedal pressure - then see it flex , for it will do a little bit .
The pivot is quite close to the floor, so I don't think there will be a big issue with the floor bending to be honest.
At least your design gives some scope for moving the pedals forward or back (with appropriate changes to pushrods)!
