Tyre compound choice
neilj37 - 10/3/08 at 01:06 PM
Which is the best tyre compound to have if you are running Toyo R888 or Yokohama A048 tyres. Car is used mostly on the road with the occasional blast around a track.
Would a medium compound be more than suitable or should I be going for the soft?
Leon B - 10/3/08 at 02:34 PM
I prefer the R888, if you're using mostly for road then go for medium compound, soft will wear out far too quick.
Aico - 10/3/08 at 03:03 PM
R888 needs less heat so go for that one for the street.
viatron - 10/3/08 at 04:41 PM
the soft compund was never meant for street use really it was described to me by a toyo tech as a sprint tyre, one of the tiger factory cars tried it last season and it was so hot after 4 laps of lydden you couldnt touch it!
