wilwood minilight handbrake rear calipers
eddbaz - 13/4/08 at 02:52 PM
Has anyone fitted these rears and can a sierra handbrake cable be used or does a special cable have to be purchased?
RazMan - 13/4/08 at 03:53 PM
If you mean the Powerlite caliper (which has the handbrake) then yes, you can use the standard handbrake cable but it works better with the Wilwood cable.
eddbaz - 13/4/08 at 04:09 PM
yes I did mean powerlites,brain isn't engaged today for some reason,will the wilwood fit a sierra handbrake and can the length be adjusted?
RazMan - 13/4/08 at 04:20 PM
I did a straight swap Powerlites for std Sierra jobbies - the handbrake cable will slot in without modification but the Wilwood cable has the proper fittings and fits better. I couldn't justify the extortionate Wilwood price so I made do with the std Sierra one - no problems so far except that the handbrake performance is crappy so don't park on any hills.
eddbaz - 13/4/08 at 04:29 PM
Did you remove the rubber ends so the plastic part sits against the operating arm at the caliper end of the cable and I assume you have to fit the spring that comes with the calipers between the two operating arms so they are held apart when the handbarake is not in use.
RazMan - 13/4/08 at 04:55 PM
Spot on as far as I can remember
britishtrident - 13/4/08 at 05:17 PM
Do the wise thing and refit Sierra calipers.
eddbaz - 13/4/08 at 07:07 PM
why?
RazMan - 13/4/08 at 09:28 PM
I found that the Sierra calipers were much more effective - the four pot Powerlites just look better.
Dave Bailey - 13/4/08 at 09:47 PM
Hi! I have these calipers with the correct cables.. Anyone got any pictures of how the handbrake end is assembled? I can't get clearance with the chassis without modifying the Sierra handbrake.
thanks
Dave B
