Was hoping to remote mount a reservoir as the steering column UJ is hitting it.
Thought it would be an easy job....
....Typically my M/C doesn't look as though it will be easy to do?
I've tried to ID what its off on BrakesInt - closest I can find is Capri? (ran out of viewings)
I can't actually get the reservoir off, I assumed the end that wasn't screwed in was push fit....I can lift the car up it's in so
tight!!!
I've tried winding in case there's a thread, also reverse in case it's left handed.
Can't get the damn thing off & don't wanna bust it.
So taken the whole lot out
Could someone confirm or not if it is pushed in before I get medieval on it?
Also has anyone got any tips if they have remotely mounted this particular type of M/C.
1st Pic is of the M/C with the reservoir rotated out of the way.
Original master cylinder front
Original Master cylinder
James.
Original mc+res
[Edited on 20/4/08 by skidude88]
If it is a Capri and it looks like it is then you can't put a remote res on it as far as i can tell you may be able to convert a Sierra M/C but
not the one you have as it is too old.
Disclaimer blah blah blah if i am wrong then tell me pleae but info given to the bes of my knowledge
