Goodyear F1 gsd3 any good?
Valtra - 22/4/08 at 10:56 PM
these are good normal car tyres but are they any good on a seven ?
Valtra - 22/4/08 at 10:57 PM
also Yoko Paradas
size 195 / 50 15
richardlee237 - 23/4/08 at 04:41 AM
also Yoko Paradas
They are handbags aren't they ??
Valtra - 23/4/08 at 07:16 AM
usefull info I'll bear that in mind you obviously have a great depth of knowledge on the subject
Valtra - 23/4/08 at 07:22 AM
now looking at Hankook rs2
indykid - 23/4/08 at 07:30 AM
what do you want them for?
dry?
wet?
hot?
cold?
all of the above?
most people go for toyo r888s if they want sticky for warm and dry. i have them, theyr'e brilliant. yoko A048R are the ultimate in sticky. neither really want to be used on the road in the wet though.
for all round, toyo T1s or R1s, yoko 21R tend to be popular. yoko a539s if you can still get them too.
i'd think the above that you're looking at will seldom be used on such light cars, so if you want to tread that path, no pun intended, it'll be trial and error.
tom
Valtra - 23/4/08 at 07:45 AM
Mostly warm dry road use . 888s are a tad expensive ? the hankook is sold as a halfway compromise between 888's and normal tyres so I understand. Wanted 539's but not available in 15"
Davey D - 23/4/08 at 02:11 PM
i used Eagle F1 GSD3 on my 200sx, and they gave really good grip in the dry. I used them on a few track days too, and they held up quite well. Wet grip was quite good, but if you wanted to light them up then you could easily enough in the wet
