Hello,
Has any one got the dimensions of there bush, cush tube, outer sleeve, I did find a one posted a couple of days ago but I can't find it again
some pics in my archive, bush sizes.
Thanks,
They are to narrow for me, any one know what the dimensions the rallydesign bushes are
[Edited on 9/5/08 by Minicooper]
Same I should imagine
Hello,
Most bushes I've had and the rallydesign version as well I believe are 44/45 mm to fit into a 50mm box section with 3mm wall cut down into
brackets, Wisbech Engineering are 38mm width in total with the outer sleeve being only 27mm. I need to weld 1 inch tube properly on this so I need the
extra width!
Thanks Big_Wasa, as I said 38mm is'nt wide enough for my application
