keep thinking of putting rose joints on the trailing links on the road car.
I'm thinking of this cause it means i can be sure my trailing arms are the exact length.
So, where's a good place to buy them?
what size would you recommend (i've got 1/2" by 1/2" on my panhard rod).
and, i worry about stories of rose joints failing - how much should i worry on a live axle / de-dion road car trailing arms?
I used rose joints on the panhard bar for mine, The SVA man did not like them one little bit, we didnt fail me on them, be strongly recommended that i used a convetional bush design for the retest.
Tiger use a rose bush on one end of the trailing arms to the dedion unit with a conventional (Poly) bush at the other end on the R6 and B6 models.
I've got some 1/2 unf thread ones with a 9/16 bore that are aerospace spec and would be very good if protected with a rubber boot.
Real bargain at £5ea
ebay BIN
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=330241980354&ssPageName=STRK:MESE:IT&ih=014
Bushes have play in them for a reason (Not just road car comfort). Maybe consider very stiff Polyurethane ones for a happy medium?
