What size wheel studs
Pdlewis - 19/10/08 at 04:41 PM
Hi,
What size are you guys using on cortina hubs?
I ask as I have just pulled studs through my hubs for the first time (as they were new the hole needed slightly expending) the studs i have are 65mm and they seem very long I put 10mm spacers behine my sierra build wheels to stop the tread sticking out past the wheel. Should i get the next size down? as I intend on getting new studs as i dont know if i over stressed the studs pulling them through the hub and dont want to risk them sheering for the couple of £ new ones are
oh my uprights are rally design ali replacement with ali hubs
stuart_g - 19/10/08 at 05:02 PM
I had to shorten the front wheel studs on my MNR ali hubs as the shortest stud was still too long for the wheel nuts I had supplied with my Team Dynamics wheels.
Pdlewis - 20/10/08 at 02:34 PM
I didnt think you could cut them as they are tempered and cutting would reduce the streangth?
liam.mccaffrey - 20/10/08 at 02:57 PM
not sure if this is a helpful comment or not, but granada studs are the perfect length for regular tina hubs
