(v) amature builder looking for advice about front sus bracket mounting
doughie - 12/9/11 at 06:09 PM
have jigged up the front sus brackets and offered them up to the chassis; the brackets are bigger than book and have made LC 22mm further back than book so the positioning of LA/LB and FU1/FU2 will be slightly different
looking for comments
LA/LB will be around 5mm inward
[img] jig
jig
[/img]
top of FU's will be inside J1/J2; but will S and T pick this up ok?
[img] jig
jig
[/img]
designer - 12/9/11 at 06:23 PM
You are going to weld the front upright chassis members using the brackets as locators?
Can't see any problem.
mark chandler - 12/9/11 at 06:25 PM
1st or second book, the first has errors !
If you are making your own bones then you taylor to suit, just make sure you build in 7 degrees castor when finished.
MikeRJ - 12/9/11 at 06:32 PM
That is really the only way to do it properly. Since the position of the holes in the brackets is very important, it makes sense to locate these in the correct position (using a jig) and then position the FU chassis members accordingly.
Fred W B - 12/9/11 at 07:11 PM
Seeing as the bones are made already he will have to position the brackets (or use shims?) to get the caster right.
Fred W B
doughie - 12/9/11 at 09:08 PM
cheers guys - yes am looking to locate the uprights using the brackets in the jig... so there's no issues if FU's are slightly inboard at the top?
first book... 7 degrees... i've built in around 5.5 in the jig... but have an element of adjustment using washers as spacers in the brackets?? hope that's ok
mark chandler - 12/9/11 at 09:12 PM
Perfect, locate the brackets correctly then add additional strength if required and you will be all right do not try and make the brackets fit the frame!
Regards Mark
doughie - 9/4/12 at 02:57 PM
All fitted and tacked up some pics...
[img] 060412
060412
[/img]
[img] 090412
090412
[/img]
[img] 090412
090412
[/img]
[img] 090412
090412
[/img]
all comments gratefully received - your knowledge and advice is appreciated - is there anything i need to do/ know about at this stage??
[Edited on 9/4/12 by doughie]
