Author: Subject: Impact of tyres on lap times
Ivan
posted on 14/2/12 at 07:25 PM Reply With Quote
My Cobra currently runs very ordinary low performance 15 x 295 X 60 tyres on the back and 235's on the front - the only choice I have for the wheel size. I have often wodered if changing to 17 or 18 inch wheels and some premium tyres in similar widths will give significantly improved lap times.
On a 1' 30" lap how many seconds do you think I would gain from such a change. I don't think I will find R888s in those sizes so would be limited to the better Pirellis or Yokos.
bi22le
posted on 14/2/12 at 08:12 PM Reply With Quote
It will obviously make a diference because sticky black stuff is better than non sticky stuff.
From the track days I have done the biggest lap time gains (or losses depending on half empty or half full!!) I have found is improving my skill, my familiarity with the car, my familiarity with the same circuit and setting the car up better.
I think that if your maxed out on the above then invest in new rubber but with the sizes your talking about thats a lot of monies. If your not maxed out on the above then I would do the above first unless your tyres are really bad or deep down you really want to change your wheels!!
From what I have read on here lower profile tyres dont work as well on lighter, stiffer set up cars as the tyre wall deflects and increases contact patch. I am not sure if the same applies to heavier brute V8 Cobras, someone will answer that one soon.
Good luck with the need for speed.
This will be an interesting thread, I am always ears open on how to get round a track faster.
Please read my ring story:
LBMEFM
posted on 14/2/12 at 09:05 PM Reply With Quote
Lydden lap times in my MK Indy-Blade on Yoko's was circa 50 sec's, changing to R888's resulted in an immediate 48 sec's and the car felt so much more stable.
will121
posted on 14/2/12 at 09:22 PM Reply With Quote
If you after out and out best lap times then if you go to 18 inch rims there are lots of options of slicks, I was amaised at the difference but be ware better gripping tyres will highlight over weaknesses like suspension, bearings, oil etc
Benzo
posted on 15/2/12 at 12:29 AM Reply With Quote
Is this true? I certainly won't be changing my 13's to 18's to chase faster laptimes!!
MikeRJ
posted on 15/2/12 at 09:15 AM Reply With Quote
There is at least as much choice in 15" rim sizes, if not more. Every stage rally I go to there is a van selling slicks and mounting tyres for people, and I reckon 90% of the tyres he stocks and sells are 15".
Ivan
posted on 15/2/12 at 12:14 PM Reply With Quote
Maybe in Britain but there is very limited availability of of tyres in 15" that are +260 width in South africa and are suited for road use.
Fred W B
posted on 15/2/12 at 06:16 PM Reply With Quote
On a 1 min 20ish lap here in PE, going from good road tyres to slicks is reckoned to take 2 seconds off the lap time. So at a guess I would expect to see a minium of 1. 5 sec to maybe 2 going from ordinary to good road tyres.
Fred W B
You can do it quickly. You can do it cheap. You can do it right. – Pick any two.
Ivan
posted on 15/2/12 at 07:37 PM Reply With Quote
Thanks for that all - I guess what I will do is spend more time on the track with what I've got, and concentrate on suspension and my own driving and once I am happy with my own performance, and feel I have suspension settings good enough, then review the tyre situation because as said they are the most expensive of the options and best left to last when I can get the most benifit from them. It's just that new wheels are such fun and can totally change the look of the car.
Once I have the new tyres I realise that I will most probably have to change suspension settings again.
