Author: Subject: 100MM & 108MM drive stubs interchangeability
tilly819
posted on 5/3/12 at 07:41 PM Reply With Quote
Hi all
Im just playing with an idea and was wondering if you can swap the outboard drive stub from 100mm to 108mm without changing the hubs??????
reason i ask is i have a complete set of 100mm lobro shafts with stubs and hubs from a sierra and i want to use the hubs but then connect them to a different drive shaft which has a 108mm lobro so can i just change the Stub for a 108MM one or do i need to change the Hub as well
hope that makes sense
cheers
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
