AndyGT
| posted on 14/3/12 at 09:21 AM |
Reversing Light Switch Wire
Using a xflow on an engine transplant and have looked "high and low" for the little wire (with an L-shaped rubber boot) connection to go
on the back of the gearbox for reversing light wire. Anyone got one floating around? If I remember well, the wire is only about 6 inches long, just
enough to go through transmission tunnel where it then connects into the main wiring loom.
Would/Could use a spade connector but there is very little space in transmission tunnel and the original ford connection is similar to brass press you
would find on a jacket so mega-difficult to solder/make something other than the standard connection. ANY help would be greatly appreciated.
Thanks in advance - Andy
nothing is impossible
everything is possible
RK
| posted on 14/3/12 at 01:11 PM |
On my Nissan transmission, I couldn't find the correct wire either, and when I thought I did, it was very hard to reach. I ended up forgetting
it and installing a switch on the dash. Easy. I don't think your IVA requires it does it?
pekwah1
| posted on 14/3/12 at 02:39 PM |
IVA does now require a reversing light unlike the SVA
