degmwilliams
| posted on 3/6/12 at 06:42 PM |
Tiger Avon wishbones
Does anyone know if any one else sells these other than tiger? Or if any one has a set for sale?
Building a tiger Avon st170 (slowly)
degmwilliams
| posted on 3/6/12 at 07:59 PM |
Iv justed priced up from tiger and a set is £421.08
jossey
| posted on 3/6/12 at 08:08 PM |
ive just built a full set for £40.00
fronts and rears.
Just be aware that the wishbone plates on ebay dont work. as they are not wide enough.
the tiger book has the drawings so they can be made yourself or employ someone.
The Haynes or Champion wishbones DONT WORK.
plus the wishbones in the book are for the cortina uprights NOT sierra.
Ive not seen anyone else who sells them as they are NOT standard to anything else.
[Edited on 3/6/12 by jossey]
David Johnson
jossey
| posted on 3/6/12 at 08:12 PM |
ps myt advice is borrow some off someone and build jigs and get on with building some.
I got the plates made up for £12 a pair.
1" tube 10M
3mm steel
36mm Tube 2m
Thats about it. the exact sizes are in the build manual.
CHEERS
David Johnson
degmwilliams
| posted on 3/6/12 at 08:33 PM |
Im using cortina uprights. Does it have the measurements for the plates? i might get some made and start knocking them out abit cheaper.
jossey
| posted on 3/6/12 at 08:48 PM |
No it doesn't have the measurements for the plates but I have. I can send you them.
I'm using the sierra uprights hence the mention. I had to alter the top wishbone.
I would build a jig using existing wishbones as building new ones are a pain.
If you borrow some it will take minutes :-)
The wishbone measurements are simuar to the locost plates you can get off eBay but 20mm wider at the top. The Haynes manual has the plate plans.
David Johnson
degmwilliams
| posted on 3/6/12 at 09:32 PM |
In the book it stats that both plates on this wishbone are 10mm thick plate, on this picture the plate only looks to be about 4mm max.
I would be interested in the drawings please if you can send me them.
I know what you mean about setting up a jig with a set thats already made but not sure if i would be able to borrow any, i dont think il have to much
trouble from scratch.
snakebelly
| posted on 4/6/12 at 07:05 AM |
just about to build a set for our Avon, i have 2 brand new front bottom plates i am going to ask Andy to cut a few for me, i am going abroad in the
morning for 10 days but if you can wait i can probably help you out with a set.
Minicooper
| posted on 4/6/12 at 11:11 AM |
1" tube 10M
3mm steel
36mm Tube 2m
CHEERS
Hello Jossey,
Did you use seamless or ERW for the 1" tube? and also what wall thickness
jossey
| posted on 4/6/12 at 12:41 PM |
No need for seamless as I weld the seem at the plate side.
Will check thickness n let you know
David Johnson
degmwilliams
| posted on 6/6/12 at 06:28 PM |
Did you check the thickness of the tube? And can you send me the plate drawings when you get time please? did anyone see the picture I put on above?
Why do the drawings say 10mm when in the picture it's not?
