gunman
| posted on 6/6/12 at 09:06 PM |
Bleeding brakes
I have recently upgraded my diff in my Tiger Cat E1 to LSd with bolt on shafts and upgraded to rear disc brakes. I also have upgraded the fronts from
sierra 240mm discs to 260mm discs. I now cant get the pedal hard, theres a fair bit of travel but have bled the brakes out over 5 times. The pedal
wont go to the floor, maybe half way down and then goes hard. I even went and bought an eezibleed to try that but no difference. MC is a std sierra
item.
On a test drive at 35mph on a straight road I hit the pedal hard and the fronts locked up. Could this just be due to the larger pistons in all 4
calipers or am I missing something when bleeding? I have searched every joint in the pipes and found no leaks anywhere.
Ben_Copeland
| posted on 6/6/12 at 09:08 PM |
Are the bleed nipples all at the top??
At the bottom and you wont get all the air out !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
gunman
| posted on 6/6/12 at 09:13 PM |
Yes, all at the top.
Ben_Copeland
| posted on 6/6/12 at 09:28 PM |
New pads that need bedding in? Can sometimes feel spongy
Ben
Roadster
gunman
| posted on 6/6/12 at 09:33 PM |
could be it, I've new discs and pads all round.
Ben_Copeland
| posted on 6/6/12 at 09:54 PM |
Bed them in, as long as it feels safe enough to drive then try it and see
Ben
Roadster
Grimsdale
| posted on 6/6/12 at 10:44 PM |
i have had problems with pitons sticking to seals in calipers, add some brake fluid behind the dust boot to lube the outer of the seal. This will work
for a bit, but it is best to dismantle and lube properly.
also double check calliper sliders move easily and are lubricated.
gunman
| posted on 7/6/12 at 05:22 PM |
Calipers should all be Ok as I have rebuilt them all with new seals and slider kits.
