Author: Subject: omega or sierra
Hopley89
posted on 7/9/12 at 09:42 PM Reply With Quote
omega or sierra
hi im building a haynes roadster with a 2.0l redtop c20xe engine
i now one of the best gear box for this is omega 5 speed
but will the diff drive shafts ect fit or is it best to use sierra rear end
hopley89
Chippy
posted on 7/9/12 at 10:01 PM Reply With Quote
I would suggest using the Omega gearbox and a Sierra rear diff, that way all you have to alter if the gearbox mounting. Then just get a prop shaft made up that fits both ends. HTH Ray
austin man
posted on 7/9/12 at 10:02 PM Reply With Quote
you will just need a propshaft making which uses the diff end for the ford and input from the omega may cos a little bit more but at leas you wont need the adaptor plate
Hopley89
posted on 7/9/12 at 10:14 PM Reply With Quote
cheers .. i will go with that then omega box to sierra diff ect
AdrianH
posted on 8/9/12 at 08:02 AM Reply With Quote
Speak with monsterob on the Haynes roadster forum, I think he has gone Vauxhall with a x20xev engine, I think basically the same.
Adrian
Why do I have to make the tools to finish the job? More time then money.
