jossey
posted on 5/1/13 at 05:08 PM |
Caliper please Identify. M16?
As above what are these?
They came with a rusty set of tina uprights I bought,
Also what size discs will I need?!?!?!
Thanks in advance.
Will electrolysis work to clean it without wrecking the internals.
David Johnson
big_wasa
| posted on 5/1/13 at 05:29 PM |
If there tina then they should be m16. I really would think about exchanging them instead of doing them your self. By the time you have bought seals
and new pistons there wont be a lot in it.
But yes you could dump them in a bucket as is and it wont hurt anything.
MsD
| posted on 5/1/13 at 05:33 PM |
look like m16's to me!
Not sure on disc size as I can't measure mine atm!
With regards to cleaning- judging by the condition its probably worth replacing the seals anyway so your method should be fine!
Mark.
jossey
| posted on 5/1/13 at 05:36 PM |
Thanks peeps :-) if anyone gets a disc size for me :-)
Dj
David Johnson
coyoteboy
| posted on 5/1/13 at 05:44 PM |
Can't you tell by getting a pad out and checking the diameter that's described by the top edge of the pad?
http://forum.onlineconversion.com/showthread.php?t=1356
[Edited on 5/1/13 by coyoteboy]
jossey
| posted on 5/1/13 at 06:17 PM |
Oh I get you now..... Right ill go look again
[Edited on 5/1/13 by jossey]
David Johnson
