Author: Subject: Steering - IVA OK?
Nickp
posted on 7/12/15 at 07:16 PM Reply With Quote
Steering - IVA OK?
I've just mocked up my steering and it all works OK, but is it IVA OK?
I'd rather find out now and rethink it rather than find out at the test station
And our Lukes first drive. He's actually impressed now that it has some car like qualities
theconrodkid
posted on 7/12/15 at 07:44 PM Reply With Quote
very tidy but you need an angle on one of the Uj,s,10 degrees i think so the shaft isnt strainght from the rack to the wheel.
ignore that,seen the angle now.
[Edited on 7/12/15 by theconrodkid]
who cares who wins
pass the pork pies
Marcus
posted on 7/12/15 at 07:57 PM Reply With Quote
Looks fine, but keep that steering wheel for IVA
Marcus
Because kits are for girls!!
Nickp
posted on 7/12/15 at 08:07 PM Reply With Quote
Cheers, I will be keeping the 'Bus wheel'
Nickp
posted on 7/12/15 at 08:08 PM Reply With Quote
It does have an angle, it's not massive though.
adithorp
posted on 7/12/15 at 08:13 PM Reply With Quote
As you have a collapsible lower section in the Sierra column (triangular bit) the angle shouldn't be needed.
http://jpsc.org.uk/forum/
Nickp
posted on 7/12/15 at 08:26 PM Reply With Quote
Ok cool
joneh
posted on 7/12/15 at 09:46 PM Reply With Quote
It would be interesting to hear the collectives opinion on the collapsible part. The UJ is only an inch from the bearing holder so will it collapse?
Or is this a mute point as the footwell would have to collapse as well which would help stop the wheel or column hitting the driver?
David Jenkins
posted on 7/12/15 at 10:11 PM Reply With Quote
That layout is almost identical to mine in virtually every respect, and it passed SVA (it was a while ago!) without comment.
You have a slight offset in the linkages, a sliding joint (the triangular bit just in front of the bulkhead), and the collapsing steering column, so you've covered the requirements in 3 ways.
Nickp
posted on 7/12/15 at 10:14 PM Reply With Quote
It's a win win win situation then.....hopefully
Badger_McLetcher
posted on 7/12/15 at 10:46 PM Reply With Quote
Same as I've got on mine mate, so I bloody hope it's OK
snapper
posted on 8/12/15 at 09:00 AM Reply With Quote
Because you can't fully judge what the tester will say I would lift the bulkhead bearing a bit giving more angle on the uj just for the test
I eat to survive
I drink to forget
hizzi
posted on 8/12/15 at 09:53 AM Reply With Quote
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/354071/M1_IVA_inspection_manual.pdf
heres a link to the iva manual, i am at the same stage with my steering pretty much the same. there is a comment about welding the tube to join the lower and upper , it should be pinned as well as welded. i put two roll pins through as well as welding
nadwgbr
posted on 8/12/15 at 11:52 AM Reply With Quote
am at similar stage of build and also have a shortened/welded steering column similar to op's....hizzi could you point me to where the bit about pinning welded tubes is mentioned in the iva manual as couldn't spot it....much appreciated, cheers.
Nickp
posted on 8/12/15 at 12:39 PM Reply With Quote
Ta, sounds sensible.
What size roll pin do you reckon?
hizzi
posted on 8/12/15 at 02:17 PM Reply With Quote
i fitted a roll pin top and bottom of my extension tube , they were about 2mm , someone posted on the haynes forum they failed for not having pins as well as the welding, not sure if that was the rule or just that particular testers opinion but its easy to do now rather than later
beaver34
posted on 8/12/15 at 03:00 PM Reply With Quote
nice pedal box, what is it?
Nickp
posted on 8/12/15 at 04:32 PM Reply With Quote
It's an OBP Premium- http://www.obpltd.com/Pedal-Boxes/Kit-Car-Motorsports/Kit-Car-Premium-V2/Premium-Kit-Car-Hydraulic-Clutch-V2-OBPKCP103 />
Nickp
posted on 8/12/15 at 04:43 PM Reply With Quote
Is 2mm substantial enough? I suppose it should really be strong enough to do the job if the welds were to fail and 2mm doesn't sound much to me.
