Northy
| posted on 7/2/05 at 10:41 PM |
Will it wee oil out?
I've got a diff fitted in the car ar the moment (non LSD). If I pull the drive shafts out will it wee oil out (its set to proper fill
level)?
Graham
locoboy
| posted on 7/2/05 at 10:46 PM |
I reckon so
Locoboy
NS Dev
| posted on 7/2/05 at 10:47 PM |
another of my really stupid replies!
Can't remember, even though I drive a Sierra, but if the filler/level plug is below the driveshaft level then yes, if not then no.............to
state the obvious! (so not much help unfortunately!)
Chris_R
| posted on 8/2/05 at 12:11 AM |
It did when I took mine off.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Avoneer
| posted on 8/2/05 at 12:07 PM |
Yes, but not much as the oil level should be slightly below the lip.
But seen as you can get the diff out with one hand, you can hold a tray with the other!
Pat...
indykid
| posted on 8/2/05 at 12:41 PM |
diff out with one hand?
bloody hell pat, you must have arms like mr t
or should that be halfshaft(just read the bulk of the thread again)
tom
(oil level should be 10mm below filler plug if set to "correct" level)
[Edited on 8/2/05 by indykid]
