mkblade
| posted on 21/5/05 at 11:31 PM |
clonking propshaft
hi everyone ,has anyone eles suffered with a clonking propshaft when pulling away in first gear im using a blade engine,with a mk made propshaft has
the slider on the front .the ujs are fine dosent seem to have any play in the center bearing but still clonks ????
thanks
OX
| posted on 21/5/05 at 11:42 PM |
a lot of the becs clunk when going into gear but the few blade engines iv heard dont clunk any way near as bad as the r1,,i think its all the back
lash in the gear box,,you could try a bailey morris prop pricy but worth it
mkblade
| posted on 22/5/05 at 08:57 AM |
it does clonk when you put it into first gear ,as you say ive seen a lot of these do the same .bot mine clonks when you first pull away about a dozen
times then change into second seems to go ???
| posted on 22/5/05 at 09:08 AM |
Release the brake while you cram it in. The problem is the solid mounts and no cush drive same as my shaft drive bike, the energy has nowhere to go.
Hellfire
| posted on 22/5/05 at 04:28 PM |
It maybe the gear selector forks and related flange's on the gear's. Hope it isn't but it seems a popular flaw at the moment on
'blade's... sorry
wilkingj
| posted on 22/5/05 at 07:45 PM |
Hmm... I am going to pick up my Bailey morris prop this week.. What do you call expensive. Mines £120. I just gave them the dimensions and the flange
sizes.
Best Regards
Geoff
http://www.v8viento.co.uk
mkblade
| posted on 22/5/05 at 09:39 PM |
that doesnt sound to bad wilkingj , i would pay that if it got rid of the problem sound real bad mine at the moement
