Author: Subject: sierra propshaft
hector
posted on 7/8/05 at 08:43 PM Reply With Quote
sierra propshaft
My xr4x4 propshaft has a rubber doughnut at the gearbox end of prop, when in tunnel will this foul any chassis rails when under hard acceleration or do i have need to get rid of it and run a solid shaft from gearbox? if so who supplys a solid splined bit without the doughnut
ps its for a luego viento
cheers colin
Chris_R
posted on 7/8/05 at 08:55 PM Reply With Quote
I think most people ditch it. Sure it's come up before.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
posted on 7/8/05 at 10:11 PM Reply With Quote
you really need a complete new prop, its not very expensive. There are places all over the country that will make one. The rubber bit is unnecessary.
Hellfire
posted on 7/8/05 at 10:14 PM Reply With Quote
the 4x4 prop is not normally used. The rubber spider is a cushioning device and is normally dumped. If you require a cushioning device in IIRC Bailer Morris do them for a price. Popular option is a direct feed...
DarrenW
posted on 8/8/05 at 09:19 AM Reply With Quote
i got brand new prop custome made but another option i very nearly did was to buy the new nose piece (the bit that fits in gearbox) and UJ from Mac#1. This can then be welded to the shortened tube. The rear UJ's are usually OK.
Carefull as you go with the welding - prop makes a mess of your legs if it fails.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 19/8/05 at 08:28 PM Reply With Quote
Propshafts
If the rubber donut (guibo) is on a female spline that slides out of the male spline in the gearbox any propshaft place can supply a new reverse sleeve yoke to suit with circlip Uj`s.
You can fit these yourself. The main points to watch are that the tube yoke (stub) is the correct fit into the tube, the tube will require warming to dull cherry then it should just pop in, and that you clock the stub and tube before tacking and welding. If you do it correctly chances are it will not require a balance.
John
PS I built propshafts for over 5 years.
