Errol
| posted on 16/8/05 at 06:48 AM |
Locost ball joints
I am building a Locost, and according to the book one is to use a Cortina ball joint, however they do not fit the wishbones, has anyone got an
alternative that I could use??
James
| posted on 16/8/05 at 07:38 AM |
What wishbones?
Your own? Or a manufacturers ones?
If you've bought MK's for example then they are designed around using a Maxi BJ.
HTH,
James
- Muhammad Ali
Errol
| posted on 16/8/05 at 10:02 AM |
I am using manufacturers wishbones. Sorry stupid question, what is a Maxi ball joint?
James
| posted on 16/8/05 at 10:42 AM |
And that manufacturer is....
This is like pulling teeth!
Have you spoken to them? Asked them what BJ they've designed them for?
Maxi ball joint as in the ball joint from an Austin Maxi! It's even mentioned in The Book as suitable alternative.
James
P.S. If you filled out your profile details and put more info in your posts it would make life a lot easier for us!
[Edited on 16/8/05 by James]
- Muhammad Ali
