pajsh
| posted on 13/11/05 at 05:53 PM |
Help! - Real Quick Question
Decided I am going to convert my top wishbones to rose joints to get some castor.
What size rose joints would people recommend?
Would 10mm bore and 10mm tread be sufficient or should I go to 1/2". Currently they have something like 10mm bolts in 13mm sleeves.
It's only the top bones I'm planning to mod at this stage. Ultimately I want to replace top and bottom but this is just clear my SVA fails
and get on the road.
I used to be apathetic but now I just don't care.
Deckman001
| posted on 13/11/05 at 06:03 PM |
Bigger the better I imagine, so go for the 1/2 " ones, Nick skidmore does them at a good price
Jason
pajsh
| posted on 13/11/05 at 06:15 PM |
Yep I was going to get them from Nick but drilling the brackets out to 1/2" might be tricky
I'll go out and have another look!
andylancaster3000
| posted on 13/11/05 at 07:47 PM |
10mm should be more than enough. If you manage to break on of those i'd think you'd be in real doo doo!
[Edited on 13/11/05 by andylancaster3000]
JB
| posted on 13/11/05 at 08:49 PM |
You should be safe with 1/2" or 10mm. But bear in mind that quality of the joint is important. I have seen some high quality 3/8" joints
(may well have been 1/4" even) that are stronger than low quality 1/2" joints.
John
Rorty
| posted on 13/11/05 at 09:14 PM |
Be careful when selecting rod ends. For example, you can buy 10mm AM-M10 rodends that have an ultimate radial capacity of 50,227 Newtons, yet a 10mm
MM-M10 has a capacity of just 20,603.
Conversely, a 1/2" AM-8 rod end has a capacity of 72,231 Newtons and a 1/2" CM-8 rod end has a capacity of 37,087 Newtons.
So, you can find some 10mm rod ends that have a much higher capacity than some 1/2" rod ends, but it's imperative you do some homework on
this before you purchase any rod ends.
Cheers, Rorty.
"Faster than a speeding Pullet".
PLEASE DON'T U2U ME IF YOU WANT A QUICK RESPONSE. TRY EMAILING ME INSTEAD!
| posted on 13/11/05 at 09:46 PM |
my homework ended at looking on the MNR website, im just going to order a full set of rosejointed front bones off him as soon as he's back on
general orders
