Toady1
| posted on 16/10/06 at 10:46 AM |
tyre pressures
what sort of tyre pressures are people running on their indy's? mines a pinto weighing 550kgs, and im running 22psi at the front and 20psi atr.
James
| posted on 16/10/06 at 11:25 AM |
Handling of my (which in suspension terms is not dis-similar to the Indy) Locost was transformed when I lowered the pressures to 18psi all round.
James
- Muhammad Ali
DavidM
| posted on 16/10/06 at 11:39 AM |
Mine weighs 550kgs and I also run 18psi.
Proportion is Everything
jos
| posted on 16/10/06 at 11:55 AM |
Mines not an indy but FWIW I'm running 18 & 18 or 18 & 16 cant remember.
Mine weighs in at 580kg & is pinto powered too
ch1ll1
| posted on 16/10/06 at 12:09 PM |
Mines not an mk
locost weighs 460kg
13 front, 16 rear
smart51
I run 18 PSI as well. I find that 2psi make quite a difference. I ran the fronts different to the rears for a short time and found that the car can
be make more understeery or oversteery this way. Tune your car to suit your weight balance and handling preferance.
Toady1
| posted on 16/10/06 at 01:16 PM |
cheers, i did have them set at 18psi all round, but the tescos air line wasnt very accurate and pumped them to 20-22! ive a trackday this friday so
ill have a play then!
mad dad
| posted on 20/10/06 at 06:52 PM |
Just checked mine (15" wheels) and they are 25 all round!!!! so will now bring down to 18....what do people run 205 x40 x 17's at???
TangoMan
| posted on 23/10/06 at 04:17 PM |
quote: Originally posted by mad dadwhat do people run 205 x40 x 17's at???
40's. Bloody hell, I hope you have your fillings well secured!!
Summer's here!!!!
mad dad
| posted on 23/10/06 at 08:33 PM |
do you think the profile might be a bit on the low side
