Author: Subject: Cortina hub nuts
RazMan
posted on 30/12/06 at 01:17 PM Reply With Quote
Cortina hub nuts
I've just been double checking a few things prior to my SVA test and just realised I havent got split pins on the front hub nuts. Is there supposed to be a castelated nut on there or a nut retainer that the split pin goes through? I've just got standard nuts on there.
If anyone has the part numbers it would be great
Raz
posted on 30/12/06 at 01:24 PM Reply With Quote
Should have a pressed steel "castellation" if that makes sense. It's possible that they may be fitted to the rear of things like VW Golf, Passat, Vauxhall Astra, Cavalier , Vectra and Ford Escort, Fiesta etc . Can't remember the nut size for the Cortina but suspect 24mm for those mentioned
RazMan
posted on 30/12/06 at 01:31 PM Reply With Quote
Thanks Rusty, After doing a bit of searching I found catellated nuts for sale on the Westfield site
... so I guess it might be an either / or situation.
As I have the nuts it seems I just need these pressed steel nut retainers then as I've got the split pins. The nut size is 5/8" iirc.
Anyone got a part number ?
[Edited on 30-12-06 by RazMan]
Raz
posted on 30/12/06 at 01:36 PM Reply With Quote
Doubt the nut size is 5/8" Thread size maybe
RazMan
posted on 30/12/06 at 01:40 PM Reply With Quote
Yep, that's what I meant - it is about 24mm across the flats
Raz
Danozeman
posted on 30/12/06 at 01:49 PM Reply With Quote
IIRC ford do the proper castlated cover things for them.
Dan
RazMan
posted on 4/1/07 at 09:32 PM Reply With Quote
Just got them from a Ford dealer for the princely sum of 42p each. All fitted now
Raz
JamJah
posted on 5/1/07 at 02:40 PM Reply With Quote
Just caught this post too late. 64p for a pair from Ford.
RazMan
posted on 5/1/07 at 05:00 PM Reply With Quote
So I was robbed !!
Raz
