COREdevelopments
| posted on 15/3/07 at 02:02 PM |
hub nuts
i stripped my uprights awhile back to be sand blasted, all painted up nicely now, but forgot which hub goes where. where does the left hand thread one
go? i currently have it on the o/s at the moment, i think it maybe on the wrong side.
anyone??
rob
Mr Whippy
| posted on 15/3/07 at 02:05 PM |
well usually the nut slackens in the opposite direction that the wheel normally turns. A safety thing.
so after having to draw a picture thats's the passenger side rear with the left hand thread.
[Edited on 15/3/07 by Mr Whippy]
COREdevelopments
| posted on 15/3/07 at 02:08 PM |
ah forgot to say it the front uprights i was talking about. sorry
Mr Whippy
| posted on 15/3/07 at 02:09 PM |
same rule applies though
yeah just noticed the live axle bit myself
COREdevelopments
| posted on 15/3/07 at 02:15 PM |
so the left hand thread goes on the drivers side, as the hub nuts on the front uprights are on the inner and not the outside face where the wheel sits
on.
yes-no-maybe???
Mr Whippy
| posted on 15/3/07 at 02:18 PM |
Oh so this is a sierra hub now I've got you, I assumed it was a cortina type, yeah your right then it the drivers side
got there in the end
bob
| posted on 15/3/07 at 02:23 PM |
Grey area as both my first set of front hubs had right hand thread, i did find left and right in the end as i thought something was wrong. Since then
i have found out that there can be some hubs with the same thread,i put right hand thread on drivers and left hand on passenger.
Another rule of thumb i was told on rear hubs is that the nut always tightens towards the front of the vehicle which makes passenger side L/H
thread.
In addition to this the nylocs ford supply are colour coded blue = R/H thread and yellow = L/H thread
COREdevelopments
| posted on 15/3/07 at 02:27 PM |
huh? so which side does the left hand thread go on? i thought it was driver side?
bodger
| posted on 15/3/07 at 03:32 PM |
Oh b*gger I've just checked mine & the front hubs have got the nuts on the wrong side. Oh well at least I found out now & not doing
seventy around a bend!
Mr Whippy
| posted on 15/3/07 at 03:35 PM |
This is quite funny really. Put simply when you turn the nut to tighten then the wheel when the car goes forward should also be turning in that
direction. The idea being if the bearing was over tight or had even seized then (hopefully) there would be no danger of the nut unwinding and your
wheel falling off, a favourite pass time for one of my trailers
Mr Whippy
| posted on 15/3/07 at 03:37 PM |
Easily done one downside of the Sierra's hub nuts being behind those covers...
COREdevelopments
| posted on 15/3/07 at 06:10 PM |
the other is the weight and huge hole at the top!!!
so left hand thread on drivers side?!?
bodger
| posted on 15/3/07 at 06:12 PM |
Actually I've just realised that on most 7's, because the steering rack is in front of the axle whilst on the sierra it's behind,
you have to swap the front hubs over. Therefore the hub nuts will always be on the wrong side unless you take the hubs apart & swap the stub axles
over. I'm pretty sure that most people don't do that. It's not mentioned in any build notes I've seen.
COREdevelopments
| posted on 15/3/07 at 06:16 PM |
huh! the man has a huge valid point!! they are the wrong way round. so which way are your threads then?
