Author: Subject: trailing arm bracket problems
cjtheman
posted on 8/4/07 at 08:49 AM Reply With Quote
started mounting bits to the chassis ( that is a very good feeling )
but when i mounted the rear axle i found when i put the donor wheels on 165x13 steel cortina wheels the tyre rubs the outside of the trailing arm bracket
the bracket is made from 50x50 box section and the bracket position is as book dim but correct centres
any suggestions most welcome
cheers
colin
posted on 8/4/07 at 08:56 AM Reply With Quote
either your axle is to narrow, you chassis too wide or your wheels have the wrong offset. Easiest solution is to either get some spacers made, or get wheels with a bigger offset. How badly do the tyres rub?
theconrodkid
posted on 8/4/07 at 09:08 AM Reply With Quote
had that on sp1 and sp3,get1/2 inch spacers should cure it
who cares who wins
pass the pork pies
cjtheman
posted on 8/4/07 at 09:09 AM Reply With Quote
i think im gonna need about 10 mm spacers but will it get better when i put lower profile tyres on as these are 165x13
( look more like lorry tyres lol )
cheers
colin
by the way it is a escort rear axle and chassis is to book spec that was the first thing a checked in case misread my tape when building
caber
posted on 8/4/07 at 09:19 AM Reply With Quote
Have a look at the wheel offset. There are lots of steels in scrappies off Fords that will fit and have different off sets. Tyre sizes will also make a difference. Wheel spacers and long studs are a bit of a bodge.
Caber
mark chandler
posted on 8/4/07 at 09:54 AM Reply With Quote
I,ve got some spacers you can have if you cover postage.
U2U me if required.
Regards Mark
