Author: Subject: Top wishbone
sammy
posted on 19/4/07 at 09:06 PM Reply With Quote
Top wishbone
I've been looking into the wishbone plans, and found a very good diagram that "flak monkey" put up in another thread http://www.locostbuilders.co.uk/viewthread.php?tid=10925
This shows the width/offset of the top wishbone (different to the book), but not the length of the top wishbone. I did a few measurements/calculations now that I have all the bits, and reckon that the top wishbone could easily be an inch longer to get more of the top joint into the threaded tube.
Does this sound right, or have I got my calculations wrong?
Cheers!
Build diaries...
caber
posted on 19/4/07 at 09:27 PM Reply With Quote
I think your calcs came out the same as mine Unfortunately I had to chop 15mm off them to get the camber right
Caber
Alex B
posted on 19/4/07 at 09:50 PM Reply With Quote
Is that the first mistake you`ve made so far?
Alex
procomp
posted on 20/4/07 at 06:53 AM Reply With Quote
Hi there is two types of the top joint. Both for the same original aplication but when made after market they have different lenght of thread.
One has a longer plain shank at the outer end and the other has thread going about 20mm further to the outer end. But both are the same overall lenght.
I think off the top off my head that it is the QH part that has the shorter thread lenght. And the TRW part has the longer but please check this your self.
cheers matt
