Author: Subject: sierra 4x4 front hubs on the rear??
Hammerhead
posted on 28/7/07 at 10:32 AM Reply With Quote
I need to have my hubs drilled to accept a different PCD. The front hubs wont be a problem, but the rears have holes in so they can be bolted to the upright.
Do you guys think that the front hubs from a sierra 4x4 would fit on the rear? are the splines for the driveshafts the same?
Opinions appreciated.
Liam
posted on 30/7/07 at 09:48 PM Reply With Quote
Hello there
Unfortunately the 4x4 front hubs have a much smaller spline than the rears so they wont fit on. How different is the PCD? If you just want to fit 4x110 wheels on the ford 4x108 you could do that with wobble bolts.
Hope that helps,
liam
Hammerhead
posted on 31/7/07 at 10:09 AM Reply With Quote
Thanks for the info. The pcd is 95.25 (Lotus) I'll have a look at wobble bolts
