kj
| posted on 15/8/07 at 03:15 PM |
Master Cylinder
Where does the decelaration valve fit into the brake system and do i need it. I have cortina disc's at the front and RS2000 drums at the back
with a 1.6 O.H.C engine.
donut
| posted on 15/8/07 at 03:19 PM |
What is the master cylinder from? If it's Sierra then you won't need one as the single outlet for the rear brakes is at the back and as
far as i remember puts less pressure to the rear. I has the Sierra MS in my last Indy with nothing in between and it was fine.
kj
| posted on 15/8/07 at 03:30 PM |
It is the Sierra M/S, thanks
RichardK
| posted on 15/8/07 at 04:08 PM |
I have fitted it, pictures in my gallery, link below. Different place to pat's (Avoneer) but same way round.
Regards
Rich
Gallery updated 11/01/2011
britishtrident
| posted on 15/8/07 at 07:04 PM |
Don't fit a G sensing valve ! it isn't suitable for a Locost.
Although most Locosts are built and pass SVA without any kind of brake pressure regulator or bias pedal box with 9" RS2000/Capri drums it is
just about possible you may need to cut down the pressure to the rear brakes if this is the case then fit a Fiat Uno or Fiat Strada/Ritmo or Lada Riva
valve and add a braket and adjuster screw to make it adjustable.
[Edited on 15/8/07 by britishtrident]
britishtrident
| posted on 15/8/07 at 07:05 PM |
Like most (but not all) master cylinder the Sierra cylinder puts out the same pressure to both circuits.
[/I]
