Author: Subject: De Dion Axle Too Small for Sierra Disc Brake Bolt in Shafts??
mattgriffiths2002
posted on 17/9/07 at 01:14 PM Reply With Quote
Hi folks,
I dont know if there is a modification or any other de dion axles for sale anywhere but the ends on my axle are too small. I have sierra disc brake bolt in driveshafts which wont fit through the ends of my de dion axle.
Any suggestions?
Matt
oadamo
posted on 17/9/07 at 01:52 PM Reply With Quote
i made one and hade the same prob. you can change the ends of the drive shafts to the push in type that will fit the de dion.
adam
ecosse
posted on 17/9/07 at 05:45 PM Reply With Quote
As above, you could try changing the outer cv's to the push in type, although I'm not sure it is quite that straight forward.
The other option would be to either re-make the buckets and trailing arm brackets on the Dedion to suit, or sell it and buy another one that fits (give JRoberts a U2U on here for either of these options)
Alex
mattgriffiths2002
posted on 17/9/07 at 06:59 PM Reply With Quote
Thanks for the suggestions,
So if I got a pair of push in shafts, I would be able to swap the ends on them and then will they fit?
Matt
mattgriffiths2002
posted on 18/9/07 at 07:22 PM Reply With Quote
HI again,
Do they make de dion axles that fit the sierra rear disc brakes? Ive seen this one which is like mine but mine hasnt got the cut out - http://locost7.info/files/suspension/RortyDeDionAxleAssembly.pdf
This describes having disc brakes on it. Im just debating whether mine would fit if I cut away the wide tubing?
ecosse
posted on 18/9/07 at 07:38 PM Reply With Quote
Fraid not, the cutaway won't alter the fact that the cv's are too big for the buckets.
Have a look here under dedion (surprisingly enough!)
http://www.3gecomponents.com/
Alex
mattgriffiths2002
posted on 19/9/07 at 10:13 AM Reply With Quote
Hi,
That looks like the one I need from that website - thanks. The only thing is I cant seem to contact them as the emails keep comming back saying they couldnt be delivered? Do you know anything about this or how to contact them in another way?
ecosse
posted on 19/9/07 at 06:07 PM Reply With Quote
U2U sent
Alex
