jonno
| posted on 7/10/07 at 09:37 PM |
Zetec sump/starter help
Been making some good progress with the 1.8 zetec install until today
i was grinding the sump (mondeo) to get the starter motor to fit the type 9, but gone too far (now got a hole )
So i need a new sump, i was going to get a Escort one anyway to get more ground clearance but is it easier to get the starter to fit or do a need to
cut more & get it welded ??
Please help
Oh needs to be a buget solution, not get a raceline one or something
Jonno
having fun on a budget
UncleFista
| posted on 7/10/07 at 10:10 PM |
If you want a Zetec Escort sump, I have one along with pick-up pipe etc. available.
Much cheapness
Tony Bond / UncleFista
stuart_g
| posted on 7/10/07 at 10:14 PM |
Jonno,
The starter motor fitted to a 1.8 zetec from an escort with very little mod to the sump, just had to file the ribs flush with the rest of the sump to
clear the starter motor body, no grinding of anything. If the sump you have needs a lot grinding off it then an escort one would be better.
Stu.
blakep82
| posted on 7/10/07 at 11:44 PM |
whats the sump made of on them? get i guess aluminium. have someone tig it back up?
any metal fabricators in your area?
[Edited on 7/10/07 by blakep82]
________________________
jonno
| posted on 7/10/07 at 11:50 PM |
looks like i'm trying a escort sump first, if not a then cvh
procomp
| posted on 8/10/07 at 06:59 AM |
Hi this is a problem that keeps poping up on a lot of the race cars using the std sump modded ect.
The problem is that not all the starter motors are the same dimensions from the different manufacturers of them. Only a few mm but try looking for
another starter even from the same original application.
cheers Matt
