Author: Subject: Removing rear brake backplate.
Nosbod
posted on 21/10/07 at 09:57 AM Reply With Quote
Not sure if i'm being a complete idiot but i'm trying to remove the brake backplate (Sierra rear drum) from the driveshaft and having a bit of a job.
The hole in the backplate seems a fraction too small.
I wanted to be sure it's supposed to fit through before i get the files on it.
I have attached a photo as i don't explain things too well.
posted on 21/10/07 at 10:06 AM Reply With Quote
Split the hub from the driveshaft and it will come off the back of the hub. Do you mean it doesn't fit over the joint on the driveshaft?
Nosbod
posted on 21/10/07 at 10:07 AM Reply With Quote
Yes, i'm in effect trying to lift it off over the back. The hub is still assembled (it came from MK like it :/ )
[Edited on 21/10/07 by Nosbod]
Colnago_Man
posted on 21/10/07 at 10:47 AM Reply With Quote
Nosbod
I had exactly the same issue last week,
It was just a case of removing as much rust/paint/debris from both in the inside of the plate and the shaft.
I then held the plate horiztonally in my workmate so the shaft dangles down then tapped it through with a mallett.
It will fit through, just very tight!
big_wasa
posted on 21/10/07 at 11:17 AM Reply With Quote
If you can get the big nut of the drive shaft the whole lot will just come to bits.
BUT its a big if
Nosbod
posted on 21/10/07 at 07:25 PM Reply With Quote
Ok thanks for the help. Will try removing corrosion etc first and try again before i attempt undoing the hub .. although i guess i may have to do this at some point during the re-furb anyhoo :/
3GEComponents
posted on 21/10/07 at 07:35 PM Reply With Quote
The drive shaft will go through the back plate. It's actually designed to do this.
A little elbow grease might be in order
SeaBass
posted on 21/10/07 at 08:29 PM Reply With Quote
Oi Colnago - get yer own avatar!
