Author: Subject: brake bulkhead fittings. where?
Pezza
posted on 11/12/07 at 05:12 PM Reply With Quote
Been trying unsuccessfully trying to find some male bulkhead connectors for going through brackets etc.
None of the local factors have them.
Where did you guys get yours from?
Ben
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
tegwin
posted on 11/12/07 at 05:29 PM Reply With Quote
Rally design
John Bonnett
posted on 11/12/07 at 05:56 PM Reply With Quote
quote: Rally design
I'll second that. They supply all the fittings you need plus the self-assembly Euroquip braded brake pipe. This is easy to cut and of course you can make your pipes to the exact length you need.
John
Macbeast
posted on 11/12/07 at 06:01 PM Reply With Quote
Russbost on here is tops for brake pipes
posted on 12/12/07 at 07:26 AM Reply With Quote
Originally posted by John Bonnett
I was informed that would not pass SVA so to play it safe, use the goodridge crimped fitting, assembled by RD.
Having said that, there are others on here I think who have passed with these; requires proof that the fitting has internal support; SVA man said I would need to show fitting and they would need to be stamped by manufacturer so that it can be asertained they are same as the o ones on car; RD won't supply any info about this but you do get a letter stating the crimped ones are SVA approved.
