2b_pablo
| posted on 15/1/08 at 01:11 PM |
poly bushes in sierra lower arms
Guys I got some poly bushes for my sierra lower arms and when I trial fitted the arb ones they were a little loose in the hole in the arm.
Im thinking they might expand a bit once tightened but wondered if anyone else came across this?
I know the ar wont fall out but Id rather it was properly done.
Thanks.
| posted on 15/1/08 at 01:15 PM |
I'd expect them to be a tight-ish fit in the arm and then you'd tighten the nuts up with the car on its wheels so the rubber is not
stressed when the car/suspension is "at rest".
NS Dev
| posted on 15/1/08 at 07:33 PM |
I used them on my sierra xr4x4 road car and they were rather loose, both for the antiroll bar to tca joint and for the inner tca bush inside the
actual arm, but neither caused any issue.
