Author: Subject: Brake warning light on dual circuit bias setup?
cloudy
posted on 20/1/08 at 11:52 PM Reply With Quote
Can't find this info anywhere...
Will I need a sensor for both reservoirs? Or just front?
Also are there any suitable integral reservoirs for SVA?
Thanks All
James
[Edited on 20/1/08 by cloudy]
blakep82
posted on 21/1/08 at 12:04 AM Reply With Quote
i'd wondered about this too... I'm going to have 2 of everything, 2 master cylinders, 2 sensors, and 2 warning lights,
that way, if you do get a failure of one circuit, it will tell you which
________________________
RazMan
posted on 21/1/08 at 05:33 AM Reply With Quote
That's a tricky one and technically I suppose you need to have a warning on both reservoirs. Better still, if you can have one reservoir for both brakes and the clutch, then all your bases are covered with one warning switch.
Raz
MikeRJ
posted on 21/1/08 at 06:59 AM Reply With Quote
If you are using a remote reservoir with twin master cylinders then use one of the proper reservoirs that have one level switch and a divider between front and rear sections to stop a leak in one totaly draining the other.
iank
posted on 21/1/08 at 07:53 AM Reply With Quote
Yes, if using separate reservoirs for front and rear brakes you need two switches - but you can (should?) wire them in series and only have one light/test switch - doesn't matter which ones leaking the light is there to tell you to stop immediately, diagnostics should be easy just by looking at which reservoir is below min.
Clutch cylinder doesn't need a warning light.
Anonymous
posted on 21/1/08 at 10:15 AM Reply With Quote
should be in parallel to make OR function; lamp is on when either one of the switches is closed.
I have a similar set up with the reservoir and handbrake switches.
iank
posted on 21/1/08 at 10:32 AM Reply With Quote
you are quite right. I had it in my head that the switches opened on fail. my bad.
Anonymous
cloudy
posted on 21/1/08 at 05:14 PM Reply With Quote
Thanks guys, so basically I need to have remote reservoir(s) to be able to have warning sensors....
iank
posted on 21/1/08 at 05:29 PM Reply With Quote
If you use a manufacturer reservoir it will have the switch without being remote, also you can get caps with switches for the cylinders with integral reservoirs. Rally design sell a switch for willwood reservoirs (looks a bit of a hack as it looks like you have to drill the cap)
CBS sell one that looks nice though.
Bottom product on this page
http://www.carbuildersolutions.co.uk/master_cylinders.htm
Anonymous
cloudy
posted on 22/1/08 at 08:18 AM Reply With Quote
nice find! They should do nicely
James
