sooty
| posted on 21/3/08 at 05:59 PM |
AntiRoll bar - Donor ?
I'm doing a setup for a mate of mine with his rear suspension on a Grasstrack car.
Any clues to which donor car would have a AntiRoll bar approx. 18/20mm thk, 1200 mm overall width in a |__| or \__/ shape. Not too worried about the
length of 'U' arms as they could be shortened as reqd.
Thanks, will post my mods. when completed
Volvorsport
| posted on 21/3/08 at 06:33 PM |
volvo saloon 2/7/9 series , or just make one .
www.dbsmotorsport.co.uk
getting dirty under a bus
sooty
| posted on 21/3/08 at 08:12 PM |
Thanks, but
volvo 2/7/9 series ???
How can a AntiRoll bar be made by diy using spring steel bar. ???
thanks again
Volvorsport
| posted on 21/3/08 at 08:57 PM |
while to the astonishment of others , anti roll bars will function even if they arent made of spring steel .
5x50 mm flat bar and some 12g 20mm tube would be fine in your application , you can drill the flat bar for any length .
the volvo 200/700/900 share the same rear axle in different lengths - the anti roll bar at the rear is 19mm diameter , i might even have one somewhere
ill try to get a piccy .
this is a front one
http://homepage.ntlworld.com/david.slater133/antiroll1.JPG
sooty
| posted on 21/3/08 at 09:07 PM |
Thanks Volvorsport,
Yes, you may well be right.
I'll give a try.
Thanks again.
