greglogan
| posted on 24/3/08 at 01:45 PM |
More Ball Joint Woes.....
Well I got the Maxi Ball Joints as advised form here. The only problem is that they aren't tapered (at all) to match the Cortina hubs. So now
what do I do?
Suggestions?
Modify the wishbones or is there a mod for the hubs?
Greg.
[Edited on 24/3/08 by greglogan]
Women are meant to be loved, not understood.
britishtrident
| posted on 24/3/08 at 01:49 PM |
Most likely like you have got Montego/Maestro bottom ball joints.
Chippy
| posted on 24/3/08 at 05:19 PM |
Agree with ^^^^ as the Maxi ones are definately tapered, and fit the Cortina uprights without modification. HTH Ray
Macbeast
| posted on 24/3/08 at 06:10 PM |
Is it the usual mistake (I did it ) thinking that they should go on with the joint on top and the threaded peg facing down (wrong) rather than the
joint slung underneath and the threaded peg pointing up (right) ?
[Edited on 24/3/08 by Macbeast]
