v8kid
| posted on 3/8/10 at 03:14 PM |
Alloy sierra rear hubs
The sierra rear hub bearing carriers are seriously heavy.
Does anyone have experience in getting castings made in aluminium? Costs?
I presume there would be a minimum run so is anyone else interested in bare castings/fully machined versions?
[Edited on 3-8-10 by v8kid]
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
blakep82
| posted on 3/8/10 at 03:17 PM |
did the top gear caterham have them on the show when they built one at knockhill?
________________________
v8kid
| posted on 3/8/10 at 03:20 PM |
Did'nt know that I'll google it
chainsaw
Minicooper
GB engineering alredy do a lightweight version
See here
http://www.berrisford.co.uk/product_info.php?cPath=42_51&products_id=122&osCsid=256cd6sk2lafhbb80pv15ieuo7
v8kid
| posted on 3/8/10 at 03:21 PM |
Brilliant! You can always depend on Locosters
chainsaw
blakep82
| posted on 3/8/10 at 03:23 PM |
this one comes with bearings already pressed in by the look of it
https://www.caterhamparts.co.uk/product_info.php?cPath=99_149&products_id=3783
[Edited on 3/8/10 by blakep82]
CNHSS1
| posted on 3/8/10 at 03:28 PM |
quite a number available thru the autograss sources, disc and drum and granada too, BP Grassing nr Beds do some too
Gary 7
| posted on 3/8/10 at 03:41 PM |
Some more here.
http://www.drdracing.co.uk/Chassis_Components.php
v8kid
| posted on 3/8/10 at 03:58 PM |
Blimey I'm like a kiddy in a sweetie shop! These Autograssers have some desirable kit.
chainsaw
MikeFellows
| posted on 3/8/10 at 04:02 PM |
these look like just the bearings from what I can tell.
ali f27
| posted on 3/8/10 at 04:15 PM |
Hi purdy makes them we use them on race car fantastic weihgt saving Ali
omega0684
| posted on 3/8/10 at 04:27 PM |
i'd be careful, none of the ones shown so far have the caliper mounting holes or are they not on the std sierra hub (somewhere separate?), on my
cossie rear hubs there are intergrated into the casting
flak monkey
| posted on 3/8/10 at 04:39 PM |
All the ones shown are drum brake type hubs then you just use an adaptor plate to fit the caliper to.
Sera
http://www.motosera.com
snakebelly
| posted on 25/12/11 at 04:38 AM |
Anyone know if using these with bolt on drive shafts is an issue?
rdodger
| posted on 25/12/11 at 10:52 PM |
I bought some.
They are for lobro/bolt in shafts ie disc brakes with the caliper mounted elsewhere. To fit them with the drum type or wilwood drum kit would take a
lot of machining.
I sent mine back.
