Author: Subject: Stuart Taylor Castor?
DANMAN
posted on 13/6/12 at 11:18 AM Reply With Quote
Hi guys.
I was wondering if anyone knew what the castor angle is standard on a Stuart Taylor Loco Blade Chassis. Doesn't seem to have any adjustable castor but I'm curious to where it's likely to be fixed standard?
Dan.
phelpsa
posted on 13/6/12 at 12:32 PM Reply With Quote
My Aries (same chassis) measured in at between 2 and 3 degrees both sides. New wishbones required to change it.
twybrow
posted on 13/6/12 at 02:00 PM Reply With Quote
.75 LH, and 2.25 RHS
This was after setup by ProComp. The problem I believe with my car is that Aries changed the placement of their wishbone brackets at some point during production, and their wishbones as well. I think I have wishbones not originally intended for my chassis, hence crappy castor. I am planning to have a set of top wishbones made, probably with rod ends for adjustment. ProComp were very confident that moving the efective pivot point back 25mm would have a dramatic improvment on steering feel and self-centreing (due to the added castor it would give).
