Author: Subject: Where to source custom hardened pins?
cloudy
posted on 6/11/12 at 12:04 AM Reply With Quote
Am repairing a quaife diff, and need to replace 8 pins approx 6mm diameter 30mm length, but they need to be hardened steel - any ideas where I might find such a thing?
James
www.warnercars.com
blakep82
posted on 6/11/12 at 12:09 AM Reply With Quote
quaife?
________________________
Alan B
posted on 6/11/12 at 02:47 AM Reply With Quote
How about dowels?......of course they would need to be a standard size like 6mm or 1/4"
snapper
posted on 6/11/12 at 06:06 AM Reply With Quote
They will be hardened to a specific Rockwell hardness I suspect,
I eat to survive
I drink to forget
liam.mccaffrey
posted on 6/11/12 at 07:20 AM Reply With Quote
M2 M3 M4 M5 M6 Dowel Pins Hardened and Ground Steel Dowel Pins Packs of 4 or 10 Possible?
Build Blog
Build Photo Album
cloudy
posted on 6/11/12 at 07:24 AM Reply With Quote
Dowel pins are what I need! Thanks, will try quaife but they usually wont sell spares...
James
www.warnercars.com
hughpinder
posted on 6/11/12 at 08:38 AM Reply With Quote
rs sell some sizes:
http://uk.rs-online.com/web/p/dowel-pins/0270653/
Regards
Hugh
jon200
posted on 6/11/12 at 09:17 AM Reply With Quote
Dowel pins aren't always hard, especially RS ones. Unless it specifically says they are. RS are good but can be pretty basic when it comes to these things. I can harden 416 stainless if needed in a vacuum hardening machine at work. We may even have 6mm bar but I don't know what tolerance it is. I'd have to check what Rockwell reading bits too though.
Alan B
posted on 6/11/12 at 11:07 AM Reply With Quote
Agreed dowel pins in general aren't always hard...but hardened dowel pins always are... Those are usually made from a tough steel then case hardened and precision ground to a very close tolerance.
jon200
posted on 6/11/12 at 12:20 PM Reply With Quote
I was just pointing out that a dowel may be soft and not necessarily hard that all.
hughpinder
posted on 6/11/12 at 12:22 PM Reply With Quote
Just checked up - it seems RS ones under 4mm are 'soft' and 4mm+ are case hardened. I newver realised that!
Hugh
Alan B
posted on 6/11/12 at 12:23 PM Reply With Quote
I know, and it was a good point.........it was just a tongue in cheek response by me......
