Author: Subject: Fury Wheel Size Change
Neadles
posted on 12/2/13 at 02:12 PM Reply With Quote
Just want some opinions after doing some searching and reading, I have a fury blade with freelander diff currently running, 15x7 ET37 OZ superleggera on 195/50/15 with 25mm spacers all round.
Now in the interest of a more track orientated car I want to change the setup to 13x6 front with 195/60/13 tyres and 13x7 rear with 205x60x13 rear with ET 23 all round and retaining the 25mm spacers.
I believe this will improve my handing and the rotating mass improvements, do other people agree with my thinkings before I buy some new wheels?
adithorp
posted on 12/2/13 at 02:47 PM Reply With Quote
ET37 with a 25mm scacer is effectivly ET12.If you switch to 6" wide ET23 rims then the outer edge of the wheel will be about 1" further in.
13" will be better but I'd aim for ET18 ish as thats what Jeremy designed it for.
EAOE as that's all done in my head.
http://jpsc.org.uk/forum/
Neadles
posted on 12/2/13 at 08:26 PM Reply With Quote
So am I right that by your thinking i need to keep a large offest wheel to keep close to 18 or a wheel with and offset of 18?
Also I am a bit confused in the offset being 12, if the spacer moves the wheel positively away from the hub then, will this not increase the offset in relation to the axel hub? I was under the impression that offset was taken as a line in the center of the wheel so a spacer is irrelavent? If the wheel mounting faces at the center it would be an offset of 0 and if the wheel mounting face was closer to the axel hub would give you a positive offset and visa versa?
Correct me if I am wrong, are you saying it was designed to have an offset of 18 if bolted direct to the axel hub with no spacer?
Thanks fro the reply!
hobbsy
posted on 13/2/13 at 01:25 AM Reply With Quote
Based on your offsets and widths I think the fronts would be near enough the same if keeping the 25mm spacers or within 1 or 2mm and the back ones will stick approx half an inch further out.
If this is all down to weight saving though and it's benefits choose your 13" replacements carefully as very few will be lighter than your existing 15 x7 superleggeras at under 5kg each unless you got split rims with magnesium like MB rims. Eg compo cxr's are actually heavier in 13".
jeffw
posted on 13/2/13 at 06:23 AM Reply With Quote
If you are changing the rims then you want shot of the spacers so ET12 would be correct if you where using the same rim size. As you are going from 7J to 6J on the front the outer edge would be 12.5mm further in than the 7J so I would suggest ET23 on the front and ET12 on the rear to maintain the outer rim position.
The other thing to note is there is no performance 195/60 13 I'm aware of. The common sizes are 185/60 and 205/60. The big advantage is that tyres will be cheaper
dhutch
posted on 13/2/13 at 09:34 AM Reply With Quote
Off set is the measurement from the mounting face, to the centre of the wheel, so assuming the spacer is smaller then the offset, it reduces it.
Daniel
Neadles
posted on 13/2/13 at 12:59 PM Reply With Quote
Daniel
Ok great thanks that clears things up cheers
Thanks you've raised some good points as I was thinking I wanted rid of the spacers as they aren't hubcentric anyway.
Also cheap Is good!
dhutch
posted on 14/2/13 at 08:36 AM Reply With Quote
Originally posted by Neadles
Also cheap Is good!
I have switched to 185 all round, from 185/205 simply down to cost and the premium on the larger tyre, depends what your use is obviously, but I find the 185's perfectly acceptable for fast road use anc autotesting.
Daniel
Neadles
posted on 14/2/13 at 09:42 AM Reply With Quote
Thanks Daniel, I will be split between both road and track so will see what the tyre temps look like when out but with the light engine I would say should be find.
One last question any Fury owners running ET23 on the front without a spacer, just Steve from furysprotscar said the tyres may touch the front of the chassis? Any one had that experience?
Thanks for everyone's comments!
Chris
adithorp
posted on 14/2/13 at 10:03 AM Reply With Quote
I've got 13" 6.5j ET18 rims on the front fitted with 185/60/13 and they don't touch on lock.
With 13" 6j ET23 rims you should just clear, as theoretically the inner rim edge would be in almost the same position as mine. (5mm further in on the centre line but 6.5mm narrower from centre to rim). If anything you should have fractionally more clearance, if everything else is the same.
I did have 15" 7j ET35 on at first (for SVA) and they touched the chassis on full lock, so had to fit stops to my rack to prevent it. Changed soon after to 13" and removed the stops.
Neadles
posted on 16/2/13 at 09:52 AM Reply With Quote
Thanks for your help I will be looking soon as for new wheels then and getting rid of the old ones!
