andyb64
| posted on 6/6/05 at 12:22 PM |
Anti roll bar
I'm in the process of making a front anti roll bar for my car. Do the kits available of the shelf mount onto the lower wishbone using the
shocker mount. If so do they use a special bolt of just a rose joint of the same diameter as the shock mounting bolt.
I hope that makes sense ?
Andy...
pbura
| posted on 6/6/05 at 01:27 PM |
I don't see any problem sharing the shocker bolt, and a rose joint would be fine, too. Alternatively, you could bush your joints.
There's a few pics on this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=6859
I don't think clamping to the lower wishbone leg is a good idea, unless the bar is light, and the wishbone quite sturdy.
Pete
Pete
ChrisGamlin
| posted on 6/6/05 at 02:18 PM |
You don't need a rod end anywhere near the size of the bottom shock bolt though (1/2"?), and it will probably cost you £20 per joint
minimum.
You could do like Westfield do, and make up a little bracket that bolts onto the shock mount like this
or just weld on a little lug directly onto the bottom wishbone
NS Dev
| posted on 6/6/05 at 03:09 PM |
.........................or, if you have 1/2" wishbone bolts, machine some new bolts from 3/4" EN24T hex bar, with a "normal"
shocker bolt and a protrusion from the centre of it's head stepped to take a 3/8 or 5/16" rose joint and either threaded for a retaining
nut or drilled and tapped for a retaining bolt.
pbura
| posted on 6/6/05 at 03:46 PM |
Hmm, Westfield sells their kit for £236. I'll bet if someone offered a kit for Locosts for under £150 they'd do a big business.
Pete
pbura
| posted on 6/6/05 at 03:54 PM |
Found one!
http://www.catmotorsport.co.uk/parts.htm
Pete
