Author: Subject: gemini ride height
river jumper
posted on 9/8/05 at 02:20 PM Reply With Quote
gemini ride height
can any one help me im setting up a autotune gemini rolling chassis, and require the ride height for the front and rear to the bottom of the chassis, so I dont have to mess about lifting the body on and off, as I am fitting a
4age and it is pretty tight and sits very low down, trying to work it all out.
Thanks alot
Trev Borg
posted on 24/8/05 at 08:10 PM Reply With Quote
The ride height is going to depend on the rate of the springs you have, the weight of the engine, and the amount of preload.
I have the pre load wound right to the top to gaet as much clearance as poss. The big Alfa has the sump chopped but still hangs down low.
[Edited on 24/8/2005 by Trev Borg]
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
