Author: Subject: Master Cyl Confu?sion
Rob James
posted on 18/8/05 at 11:21 AM Reply With Quote
I am sure this has all been covered before but here goes. Ford cast Master Cyl with three outlets.What goes where? should I use a balance valve or should the 2 front calipers have one outlet each and the 3rd for the rear brakes....help I am totally confused..Also using seirra pedal box and the pedal to master cyl plunger is missing and ideas.......Rob
James
posted on 18/8/05 at 11:30 AM Reply With Quote
Hi Rob,
Front two outlets to the front. 1 to the rear.
Fit an inline bias valve in the rear line if you want one. Use a Fiat Uno one- cheap, ali and easy to use/mount.
As for the plunger, go to the scrappy and get one! Make sure you keep the clevis pin. I made mine from a combination of the adjustable Sierra pin one with a Nissan Micra's clevis pin mechnaism. All joined to my own pedals.
HTH,
James
[Edited on 18/8/05 by James]
Surrey Dave
posted on 18/8/05 at 05:15 PM Reply With Quote
I've yet to see a post that says the rear bias valve is nessecary , you need more rear brake bias if anything............
MikeR
posted on 18/8/05 at 05:49 PM Reply With Quote
errrm - thats the complete opposite of all the wisdom i've seen. Can't think how to phrase this without it seeming confrontational, its not supposed to, do you have any evidence to back this up?
With the standard cortina brakes at the front and 8" drums at the rear on the escort m/c then you'll be ok (Based on one member putting the figures through the girling computer a few years ago).
I believe anything more brakey at the rear and you'll need to reduce the pressure. I've got 9" rear drums therefore i'm using a pressure reducer.
forgot to add, for a road going car.
[Edited on 18/8/05 by MikeR]
Surrey Dave
posted on 18/8/05 at 06:29 PM Reply With Quote
Most people seem to fit the Fiat bias valve and report that they have adjusted it so it has no effect......
My car has an Escort M/cyl ,M16 calipers on the front, did have 8" rears now got 9" rears, plummed in with 2 front m/cylinder outlets going to front ,single rear outlet going to rear, on the SVA the axle weight split front to rear was very even, my rear brakes have never locked or even shown signs of it........
Thats my experience/evidence......honest
Check this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=24925
[Edited on 18/8/05 by Surrey Dave]
posted on 18/8/05 at 07:51 PM Reply With Quote
mine has no reducer anywhere, ive managed to lock one front wheel in a corner, and made them both scrabble in a straight line, but never lock fully. Back end has never locked, though it does drift kart-style into corners under hard braking thats standard cortina parts all round, to my knowledge
posted on 18/8/05 at 08:21 PM Reply With Quote
I too have Cortina front calipers and Escort 9" rear drums, and passed SVA without any bias gadget.
As it happens, I tested my brakes today on a quiet back road - full braking at around 50mph - the fronts locked as the car slowed, but the rears didn't.
