Author: Subject: escort axle rs2000
kevin booth
posted on 28/10/05 at 08:09 PM Reply With Quote
escort axle rs2000
Got oil seeping past main nut in centre
flange, should there be a seal there or something ?
paulf
posted on 28/10/05 at 08:23 PM Reply With Quote
Hi Kevin.
Theres no seal in the centre of the flange , dont be tempted to tighten the nut though, as there is a crushable spacer that sets the preload.If you tighten more than the preset amount the spacer will be crushed and the bearing preload overdone, the spacer then has to be replaced.
It may be the pinion seal however , to replace this you need to mark the flange and nut , unscrew counting the number of turns, replace the seal and tighten the nut to exact original position.
Try a few searches on pinion seal replacement.
Paul
omega 24 v6
posted on 28/10/05 at 08:39 PM Reply With Quote
MMmm strange one but not impossible. It's not possible there's too much oil in there? is it?
You might have to remove the nut and use a sealant on the threads. Studlock or threadlocker would do.
As already mentiond don't overtighten the nut or you'll upset all the diff backlash settings.
kevin booth
posted on 28/10/05 at 10:08 PM Reply With Quote
Have removed nut to have a look, how do i put it back wright ?.
kevin booth
posted on 29/10/05 at 07:30 AM Reply With Quote
had took it of before i knew
not to, now in poo!
