Author: Subject: What have you used
locoboy
posted on 4/4/06 at 08:54 PM Reply With Quote
What have you used
What have you used to join the steering column UJ to the steering rack UJ/Flexi joint?
Steel Tube?
Solid bar?
anything else????
Locoboy
chris_harris_
posted on 4/4/06 at 09:11 PM Reply With Quote
Nice bit of steel tube, quite thick walled if i recall, didn't want to twist it doing 17 point turns and was going to up to a quick rack one day too.
Regards Chris
posted on 4/4/06 at 09:20 PM Reply With Quote
ive made 3 different downlinks from both 19mm 16g tube and 25mm 12g. None have failed even on track use. I tend to pick whatever tube will fit over the bits i happen to have lying around
NS Dev
posted on 4/4/06 at 11:07 PM Reply With Quote
7/8" OD 1/8" wall cold drawn hydraulic tubing.
We use it for very high pressure water line at work and have loads of offcuts so it's quite handy!
Kissy
posted on 5/4/06 at 05:54 AM Reply With Quote
3/4" CDS with Montego/Maestro splines brazed into the ends (That's my column and links). I used two 3/4" i.d. pillow blocks with pressed housings (much lighter than cast)
posted on 5/4/06 at 07:23 AM Reply With Quote
Heavy gauge steel tube, with the Sierra UJ at the top and a Maestro UJ at the bottom.
locoboy
posted on 9/4/06 at 04:25 PM Reply With Quote
I take it that the maestro splines are the same as the splines on the MKII escort rack then?
Locoboy
