COREdevelopments
| posted on 20/3/07 at 01:32 PM |
WIDE OR NOT (help)
i have worked out the widths of my front and rear axle.
REAR is approx 1404mm
FRONT is approx 1260
its a locost chassis using sierra front uprights and a toyota corolla rear axle.
the rear axle is 72mm wider on each side than the front.
my point is:-
(A) shall i buy wider front wishbones like MNR ones to widen the front as i like the look of the wider front?
(B)leave it as it is and just work out what offset i will need in the front and back?
any help and advise would be appreciated
thanks
rob
[Edited on 20/3/07 by COREdevelopments]
procomp
| posted on 20/3/07 at 01:59 PM |
Hi go wider at front by at least 100mm overall / 50mm per side.
cheers matt
COREdevelopments
| posted on 20/3/07 at 02:13 PM |
so i should really buy or make some new bones, which should be 2" wider each side? also does anyone know the front track of a indy or mnr?
thanks
rob
