ditchlewis
| posted on 16/4/07 at 09:16 PM |
Are the front & rear Track Of the mk indy the same?
Hi Guys
Just a quick question, on the MK Indy are the front and rear track (width) the same ? or is it wider at the rear?
I'm going to set the tracking with four axle stands and string, and i was hoping it would be an easy job.
many thanks
Ditch
Hammerhead
| posted on 16/4/07 at 09:21 PM |
mines wider at the back. but thats mainly because my rear wheels are 225 and the fronts are 195
Guinness
| posted on 16/4/07 at 09:39 PM |
When I had mine on the back of a Brian James Minno trailer both sets of tyres just kissed the sides, so without going outside to measure, I'm
saying they are the same.
HTH
Mike
ReMan
| posted on 16/4/07 at 10:26 PM |
FWIW, the Sierra has 14mm wider at the rear.
Wether thats been built out in the Indy??
ditchlewis
| posted on 17/4/07 at 07:31 AM |
many thanks lads
it looks the same but i was not sure.
i'm going to set the tracking putting string lines down each side of the car touching the wheels.
ditch
mad dad
| posted on 17/4/07 at 10:26 AM |
sorry but note to hammerhead, how do you get 225's to fit have you got wider arches if so where from (MK i spose is the obvious
answer.....)????? cheers
| posted on 17/4/07 at 12:01 PM |
Can you not fit 225 tyres on a wheel with a greater et offset to get them under the arches?
Phil
Hammerhead
| posted on 17/4/07 at 12:16 PM |
I'm designing my own bodywork, so I will just build the extra width in! otherwise I suppose mk would be the place.
Also my wheels are off a lotus 340r (magnesium mmmmm) So I had to have special hub adaptors made. This gives an offset of about ET38
