Big Stu
| posted on 15/5/07 at 08:58 PM |
Cleaning internal threads
Hi All,
I am trying to get a new track rod end in a track rod that has been in the garden for a while. The threads are 11/16 unf normal and left hand, and
taps for these are not easy to come by. Anyone got any tips for cleaning up internal threads like this.
It gets about a quater of the the way done then just locks up.
Any suggestions welcome
Stu
| posted on 15/5/07 at 09:05 PM |
do you have an old screw or similar with the correct thread that you could cut a gash in to make it a little tap like?
That or soak in vinegar.
[Edited on 15/5/07 by JoelP]
big_wasa
| posted on 15/5/07 at 09:14 PM |
Small wire brush on a Dremel
cadebytiger
| posted on 15/5/07 at 09:31 PM |
yep cut grooves down a bolt.
ned
| posted on 16/5/07 at 08:04 AM |
You could always pop it in a vice and leave some wd40 in there before hand to soften/loosen any crud before running a modified bolt (as mentioned
above) down the hole.
Ned.
beware, I've got yellow skin
NS Dev
| posted on 16/5/07 at 06:56 PM |
yep, groovy bolt, though 11/16 UNF is a pretty stock size, in fact if you are doing a scratch build (haven't looked to see what you are up to! )
then you will want a tap anyway as 11/16" UNF is stock seatbelt bolt thread size.
| posted on 16/5/07 at 07:05 PM |
11/16" UNF is a pretty large thread, not sure I have ever seen one if it exists. 11/16 "AF" spanner size is normally a 7/16"
UNF thread which seems very small for a track rod? Are you confusing spanner size with thread size?
NS Dev
| posted on 16/5/07 at 08:26 PM |
bloody good point! I do apologise, for some reason I can't tell the difference between 11/16 and 7/16, you're quite right, i meant 7/16 is
common!!!!
Wish I read posts sometimes, ignore my useless ramblings!
Big Stu
| posted on 17/5/07 at 11:27 AM |
I am using it on a Land rover type motor. To the best of my knowledge they are 11/16. I will try cutting a groove in an old track rod and running
that down, good idea...
Landy
